dondan
- Apr 15, 2013
Yes. Silver and black will be available.
Sorry guys but actual there is no vote time I will test both panel solutions and decide it by my own.
Right now my L9i is exhausting air towards the sidepanel. I was just surprised how poorly convection was working. Makes me think a reference GPU blower is the best way to go in the A4.If you test it with a L9i in the M1 the temps are normal, because the L9i get not directly fresh air like in the A4-SFX. This means he used nearly 70% of the hot air again that he pushed on the motherboard through the heatsink. You can resolve this in the M1 if you made a fanduct from the fan to the sidepanel. You can made a fanduct out of an rolled carton piece. It is very important that the fan is near to the airholes on the sidepanel or using a airduct in other cases.
I was thinking about a half cardboard + half ncase m1. I basically want to test how the A4 might perform with a cooler/fan very close to the Lian Li ventilation holesIt'd be interesting to see what the temperature difference is if you try it with some quick DIY ducting (just a rolled up piece of construction paper).
Unfortunately i tried to install it just now but it doesn't fit on my Asus Impact. The pipes are just too long. I have a Asrock Z97 ITX PC that I might be able to test it on but I won't be able to get to that until later this week.Looks like the AR05 performs quite good compared to the Noctua and the LP53.
http://www.nikktech.com/main/articles/pc-hardware/cpu-cooling/cpu-air-coolers/4705-silverstone-argon-ar05-low-profile-cpu-cooler-review?showall=&start=5
@ Hanakuso -Would you be able to test both heatsinks with a 92x25mm fan? Both coolers are 23mm tall so that would hit the 48mm limit. The AR05 is a hair shorter so that shouldn't have any issues with clearence.
Does anyone know how the Cooltek LP53 will fit in the A4? I know Dan bought it but with the stock fan, it doesn't seem to fit with the max height being too much. Is the plan to use a slim 92mm fan?
