QuantumBraced
- Nov 21, 2015
Interesting, let's see what their video production cycle is. I'm curious how long it'll take them to review and post a video. I hope under a week.
What kind of changes will be on the v2?
Today Linus Tech Tips got an black sample of the A4-SFX.
Yeah I definitely think it'll get sold out quickly after Linus' video goes up. Especially if Dan moves some more 2x silvers up to 1x.
Not wanting to rush dondan, but he did indicate that there would be additional production runs likely of the A4-SFX if he got 1000 units on the Kickstarter (which is effectively sold out at the last time I checked). Since I'm not Dan, I won't attempt to speak about changes for future runs, but his recent posts indicate that he's been playing around with the pushpins on the GPU side for the current production run.
I'd personally love to see this case stay as is (or minor improvements but without changes to dimensions), and follow it up with the A4XL - same length but another inch wide or so on the motherboard side to allow for bigger heatsinks, a mounted case fan, or perhaps even some entry level closed loop water coolers. It'd still be smaller than any other mITX case that can fit a full sized graphics card while allowing for greater cooling flexibility.
Darn, now I don't know if I should jump on this KS while there's still time left. or wait to see if there's gonna be an A4XL. Maybe instead of a completely different case, Dan can just offer side panels that add 20-30cm of thickness. Are the panels on both sides identical?
Probably going to sit in his warehouse forever before he notices lolYeah I definitely think it'll get sold out quickly after Linus' video goes up. Especially if Dan moves some more 2x silvers up to 1x.
Maybe not though, Linus loves SFF.Probably going to sit in his warehouse forever before he notices lol
theres never even been any talk of an A4XL until tv just mentioned it. so maybe ask dan instead of starting hype about something non-existent...
What bracket are we talking about here ? Im confused. Can any one explain ?
- Max Length:
- Complete card incl. bracket: 306mm
- Without bracket: 295mm
I don't think he is talking about that bracket, it wouldn't move the card at all. There might be a bracket in the front of the case for a ssd or something.
Hi Dan,
I am about to pull the trigger on a MSI GTX 1080 X. I see the post of you saying that it will fit, I am just a bit nervous that we don't really have a definite from you as you haven't updated the compatibility list on the first page?
Thanks,
Maybe this helps:
Asus (measure the height from bottom of PCIe Socket to top)
- ASUS ROG Strix GeForce GTX 1080 OC = fit (2mm over dualslot isn't a problem)
EVGA (measure the height from bottom of slot bracket to top)
- EVGA GTX 1080 = fit
- EVGA GTX 1080 ACX 3.0 = fit
- EVGA GTX 1080 SC GAMING ACX 3.0 = fit
Gainward
- Gainward GTX 1080 Phoenix = incompatible in width
- Gainward GTX 1080 Phoenix GS = incompatible in width
Gigabyte
- Gigabyte GTX 1080 G1 = no data (from the pictures compatible)
Inno3D
- Inno3D GTX 1080 HerculeZ Twin X2 = no data (from the pictures compatible)
- Inno3D iChill GeForce GTX 1080 X4 = incompatible in width and length
- Inno3D iChill GeForce GTX 1080 X3 = incompatible in width and length
KFA2
- KFA² GeForce GTX 1080 = fit
- KFA² GeForce GTX 1080 EX OC = fit
MSI (measure the height from bottom of PCIe Socket to top)
- MSI GTX 1080 AERO 8G = fit
- MSI GTX 1080 AERO 8G OC = fit
- MSI GTX 1080 GAMING X 8G = could be to high (too high power socket)
- MSI GTX 1080 ARMOR 8G = could be to high (too high power socket)
- MSI GTX 1080 ARMOR 8G OC = could be to high (too high power socket)
Palit
- Palit GeForce GTX 1080 GameRock = incompatible in width
- Palit GeForce GTX 1080 JetStream = incompatible in width
- Palit GeForce GTX 1080 Super JetStream = incompatible in width
Zotac
- Zotac GTX 1080 AMP! = no data (from the pictures compatible)
- Zotac GTX 1080 AMP! Extreme = incompatible in width
Using custom fans is only necessary if you want to get the best cooling performance otherwise you can use coolers like the L9i, ar05 or C7 with the default fan.
Nice, but you should really try to get some english reviews as well, german market is comparatively small.
Yes, you cannot put a big heatsink into a small case, you will not be able to OC it much.Is the verdict in yet, as to whether a big OC of an i7-6700k is possible with the relatively limited cpu cooling of the Dan case?
This may be the deciding factor for me as to getting the case or not...
It's that small silver thing at the monitor connector side that protrudes a bit over the rest of the card
A light OC should be possible, but not if you want great temps or silence... My stock clocked 6700K goes up to 80°C and is rather loud with a Cryorig C7 under AIDA64 stress test load (ok it is in a mid tower with poor ventilation right now)
Because I read very often about the topic overclocking (oc) in the thread here are my thoughts about it:
In the past oc was a hobby of mine. It was a time where oc make sense, because you could get a real performance boost. The last real generation where oc make sense was Sandy-Bridge. For example I had a real good batch of an 2500k that I oc with a big water cooling solution from 3,3Ghz to 5 Ghz. All verified with a 2h Prime95 run. This was a performance boost of 1,7Ghz on all four cores and it was 100% stable.
But today CPUs does not have the same oc capacities as in the past. For example a 6700K comes with an maximum boost of 4.2 Ghz. So with a big water cooling solution and a good batch you can reach 4.8 Ghz stable. A boot of only 600 Mhz.
In a time where resolutions like 2.5K or 4K become more and more normal more CPU power is worthless without SLI, because in the most games you will run into the GPU limit and not the CPU limit. Only SLI will get an performance boost of oc.
We have two different types of oc user. The first group have the goal to break records with their oc so they are using crazy cooling technologies like LN2 to cool the system. The second group do it with the goal to have stable oc for daily usage and to have more power as currently available. The most important thing for using oc in daily usage is that it is stable. So you have to verify that your CPU is stable with stress test tools.
E.g. the 6700k comes with 4Ghz, a Turbo of 4.2Ghz and a TDP of 95W. With the Cryorig C7 the best cooler for the A4-SFX you will have a max temp of 70-80°C running Prime95. If you now increase the voltage and push the CPU to 4.3-4.5Ghz you will easily reach temperatures of 80-95°C in Prime95. I know in games the temperatures will be 10-20°C lower, but all in all you will have much higher temps with oc, that reduce the lifetime of you components for 1-3 more FPS and only 100-300Mhz more and a fan on 100% speed.
So if oc is your hobby, you know what you do and you do it for the fun and not for 3% more FPS maybe removing the heatspreader of your Skylake CPU can give you the temp buffer to do it. But for all the other guys, I recommend to buy a normal 6700 that have a TDP of 65W. You will save money, get a more silent system, lower temps in all and you will nearly have the same performance.
he doesn't have a case yet, it says "backed". nobody has a case yet except dan. they haven't even finished the kickstarter.Per your 'sig'.... you have the Dan4 case but not set up yet? I'll be curious when you set it up, as you have the MB and CPU I'll be getting for my Mini-ITX build...I'm just not sure which case I'll end up with yet... I change my mind twice a day... sheesh...
QFTre peoples internal struggles on case buying decisions,
I'm pretty sure these guys, all the sff builders, are tired of the "oh I cant decide which case, oh I changed my mind, nope I changed it back, if it had this, if it had that, do this to it, do that, change this, change that" shit. I know I am. every one of these sff builds are designed for very different uses and comparing them is pretty much pointless. just make up your minds on what you want then buy one. we don't need to hear about it.
In idle it is unhearable and in games my GTX680 blower cooler is way louder, so I can't give you an estimate until I have a 1080. Several programs like renderers that utilize it 100% (taskmanager) make it hearable but still quiet. The C7 gets really loud only when doing benchmarks.How loud is it when gaming or just under normal load?
When I used the C7 in my Ncase on my 3570K @ 4.2 it was louder than my reference 980 when gaming.How loud is it when gaming or just under normal load?
While the Core i7-6700's specified TDP is 71% that of the i7-6700K, our sample failed to deliver substantial power savings. The vanilla model is undoubtedly more efficient but not by a significant margin. If you're leaning toward the non-K variant because of its seemingly lower power requirements, perhaps for a small/quiet build, the difference is too minor to weigh into the decision. The same can be said if you're considering the "K" version for its higher clock speeds; the level of performance increase is slight.
