DAN A4-SFX: The smallest gaming case in the world
Discussion in 'Small Form Factor Systems' started by dondan, Dec 30, 2013.
  1. jb1
    jb1 Limp Gawd
    495
    Dec 27, 2014
    Payment isn't charged until the kickstarter ends–– and this is only if the campaign is successful. For this case I'm not too concerned, but I guess that depends on Dan's minimum target.
  2. jungo
    jungo n00b
    4
    Nov 25, 2015
    Dan,
    Do you have any pictures of the two prototype cases side-by-side? This will help in deciding which color I'll get :joyful:
    Thanks
  3. hi9580
    hi9580 n00b
    3
    Nov 13, 2015
    all the major heat source components intake air directly from outside the case, psu exhaust directly out top, open style gpu directly exhaust out top, bottom and back, cpu exhaust indirectly out top through convection, since all fans are intake it creates positive in case pressure hindering dust build up, this is much more efficient then conventional case designs
  4. hi9580
    hi9580 n00b
    3
    Nov 13, 2015
    it would really help the case gain traction/popularity if you could send review samples to the top pc tech youtubers (linustechtips, hardwarecanucks, jayztwocents etc) before you start delivering to the general public
  5. Lazer1337
    Lazer1337 Limp Gawd
    249
    Feb 1, 2016
  6. iFreilicht
    iFreilicht [H]ard|Gawd
    1,348
    Sep 23, 2014
    Yeah, even if less than a tenth of the subscribers are buying a case he's selling over 400. I don't think Dan needs additional exposure, that will come on its own.
  7. dondan
    dondan [H]ard|Gawd
    1,741
    Apr 15, 2013
    Current state 5100 subscriptions ;)
    jtd871 likes this.
  8. KarateOC
    KarateOC [H]Lite
    72
    Mar 20, 2016
    Actually judging from the pic in the link below it appears that there may be enough space on the top or bottom of the motherboard tray (where the cut outs are made to thread the extender) to install perhaps at least 80mmx10mm fans, although this would in part depend on how flexible the extender cable is (well the case is 3cm higher than an itx motherboard). Just saying, not that I will probably try this, but it may help out people with heat problems such as with m.2 drives on the rear side of a motherboard.
    http://pics.computerbase.de/5/9/7/5/9/17-1080.1149845798.jpg
    Also bringing up cooling I noticed someone mentioned that they got better temps with the C7 with the fans mounted vertically as opposed to horizontally, so I wonder if Dan's results would have been even more impressive if he had mounted it vertically. This may have helped to push the hot air out of the top of the case instead of being cramped pushing againat the ram which was really closely located to the fins in the pics on page 87 of this thread.
  9. bAMtan2
    bAMtan2 [H]ard|Gawd
    1,480
    Sep 16, 2008
    congrats dan! I think this is the right way to go. the only options I would suggest for later runs are: PSU and magnetic dust filters. dust filters especially would be high profit margin! :)
    for the kickstarter, I suggest showing mid/high-end and lower-end reference/example systems, with noise measurements, and how much they cost. Example: mid/high end: skylake 6700 (non-k), cryorg C7, gtx 980ti, samsung 950 pro, and a powerful PSU. lower end: i3-6100 (per The Tech Report System Guide: December 2015 edition ), boxed intel cooler, and a R9 380 for the AMD fans (per The Tech Report System Guide: December 2015 edition ).
  10. dondan
    dondan [H]ard|Gawd
    1,741
    Apr 15, 2013
    I also thought about the possibility to add three example configuration (entry, midrage/high-end, enthusiast) of the system to the campaign, to help some bakers with finding the best hardware configuration for it. But the biggest problem is the gpu because we will se a new generation in june/july.
  11. jb1
    jb1 Limp Gawd
    495
    Dec 27, 2014
    True, although the crowdfunding campaign might be over by the time those new GPUs are out.
    Also, by any chance do you have a design for bracket mount for a radiator or disk drive behind the PSU in the case of mini-ITX sized GPU use? I remember you saying you were thinking about offering this later–– I'm planning on installing a thin radiator behind the PSU as soon as I've got the case, so I was planning on making such a bracket unless you already have one designed :)
  12. dondan
    dondan [H]ard|Gawd
    1,741
    Apr 15, 2013
    Hi jb1 currently I do not have any radiator bracket design but after crowdfunding I will take a look on it.
    HopkinsTea and jb1 like this.
  13. MostComfortable
    MostComfortable Limp Gawd
    426
    Jan 27, 2013
    Fantastic. I can't wait until the Kickstarter begins, I'm ready for this! :)
  14. jhcpw
    jhcpw n00b
    22
    Jun 24, 2015
    I'll be buying this case no matter what. But if my GPU doesn't fit, that just gives me an excuse to go Pascal ;)
  15. drklu
    drklu 2[H]4U
    2,197
    Jul 15, 2013
    Glad to see your project coming to fruition. Cannot wait to snag one of these, although I still have one empty ncase and another that needs a gpu. Guess its good to have lots of projects lined up to do ! :)
  16. baonguyen312
    baonguyen312 n00b
    34
    Mar 7, 2016
    dondan: Can you provide us any estimated price for one piece? I need to make sure that I will have enough money in bank. And also it doesn't hurt if we know it before the crownfunding.
  17. dondan
    dondan [H]ard|Gawd
    1,741
    Apr 15, 2013
    The final price is 230€. But I guess I read something about that I will get back 19% tax (german tax) for every non EU based buyer so the price will be 36€ lower (194€ = $220) for them, because they have to pay they own local tax. I will check that. :)
  18. absolut_zero
    absolut_zero [H]Lite
    77
    Sep 2, 2014
    That will be great, Dondan. I'll be looking forward to the campagin. But I still can't decide which color to get, the black or the silver.
    Oh, how about adding another tier,
    T3: A4-SFXv1 Black and A4-SFXv1 Silver :D
  19. iippo
    iippo n00b
    55
    Aug 28, 2014
    any chance of having 3rd tier for those wrestling with the idea of getting two cases? ;)
  20. dondan
    dondan [H]ard|Gawd
    1,741
    Apr 15, 2013
    I will think about this problem...
  21. 00joshua00
    00joshua00 n00b
    33
    Oct 18, 2015
    And spare parts? I think especially as the 2 side. I wanted to have spare for modding or even better, non pierced side.
  22. RJS2
    RJS2 [H]Lite
    108
    Mar 25, 2005
    Great news, dondan! I don't remeber if this had been asked - will there be a case number on the back, as a production number similar to what ncase did? Did you say there is a maximum that will be sold through the kickstarter or is there just a minumum order needed?
    With a limited number being sold and the lack of numbers it seems unfair that those that want to order more than one can and since they aren't being prepaid, only paid after the kickstarter is complete.. What happens to those orders that can't be completed due to insufficient funds? Is there a backup plan?
  23. Halfdan
    Halfdan n00b
    10
    Feb 24, 2015
    For the EU residents can you say from where the kickstarter cases will be shipped (for VAT)? Will shipping be expensive?
  24. jtd871
    jtd871 [H]Lite
    91
    Feb 11, 2015
    IIRC, all the cases are being shipped to Dan from the mfgr. Dan will then ship to individual backers directly (from Germany).
  25. dondan
    dondan [H]ard|Gawd
    1,741
    Apr 15, 2013
    @RJS2:The cases are limited to 1500 I think that is enough so they everyone will get one or two. If there are incomplete orders at the end, this ones will be unused.
    If it comes to the situation that the Count of incomplete orders lower the total count 20 cases under the min. count the project will be canceled and I will refund the money.
    Halfdan: Inside the EU there will be no extra VAT. But the price will include the German VAT(19%).
    In EU shipping will be 15€ except the small Islands and except Germany = 6€.
  26. KarateOC
    KarateOC [H]Lite
    72
    Mar 20, 2016
    So DAN Cases will be founded as of today? Should we be expecting some updates on the site or the 1st page of this thread sometime shortly? Also it would be great if we can know in advance when the kickstarter campaign will go live (once you have a hard date set) so that we can support it from day one.
  27. Lazer1337
    Lazer1337 Limp Gawd
    249
    Feb 1, 2016
    I think you can subscribe to his updates/newsletter and you will be emailed new updates
  28. dondan
    dondan [H]ard|Gawd
    1,741
    Apr 15, 2013
    Subscribe on dan-cases.com an get informed if the case is on Kickstarter.
  29. KarateOC
    KarateOC [H]Lite
    72
    Mar 20, 2016
    Have done . It appears that the site has been updated, and it is making me wonder if the DAN label on the front of the case of the new(?) artwork is an optional sticker or whether it is engraved in the case?
  30. drklu
    drklu 2[H]4U
    2,197
    Jul 15, 2013
    subbed, patiently waiting opportunity to purchase :)
  31. QuantumBraced
    QuantumBraced Gawd
    579
    Nov 21, 2015
    Happy Birthday to Dan Cases! :ROFLMAO::ROFLMAO::ROFLMAO:
    So much hard work is finally coming to fruition. The case is such a simple, elegant, and, to many of us, obvious product. Yet, it's never been done before. And that is the definition of genius. ;) Congrats to Dan and the community for getting here. I cannot wait to get my A4-SFX. Eagerly awaiting the crowd funding campaign.
    Wezelkrozum and MostComfortable like this.
  32. dondan
    dondan [H]ard|Gawd
    1,741
    Apr 15, 2013
  33. baonguyen312
    baonguyen312 n00b
    34
    Mar 7, 2016
    Sorry if this was answered before but I kept browsing the whole thread and didn't find the answer. Is Cryorig C7 the best cooler for this case in terms of performance and noise level?
  34. Kaldskryke
    Kaldskryke [H]ard|Gawd
    1,346
    Aug 1, 2004
    Maybe you missed dondan's post: DAN A4-SFX: The smallest gaming case in the world
    tl;dr: the C7 beats everything else dondan previously tested - by a significant margin - even at 40% fan speed which is "very very silent". AFAIK, the only downside to the C7 is that the fan is not easily replaced if it fails.
  35. CknSalad
    CknSalad Limp Gawd
    442
    May 27, 2014
    How about the LP53 with a thin fan? The only problem with that cpu cooling configuration is that it would be quite costly and it is hard to find a thin cpu cooling fan.
  36. Kalaminator
    Kalaminator n00b
    2
    Apr 23, 2016
    I want to buy this case for my build. Just some points.
    The price is ridiculous high for the amount of material required to build the case. Also there is no airflow engineering or anything like that involved in here. If I'm wrong show me your results then. And I'm not talking about the temperature results you show on this threath.
    Just as an example of an expensive ITX case I'll give you EVGA Hadron Air, which at release was unique.
    You charge 230€+Tax (I hope you don't mean IVA)!!!!
    The case does not include or have fans, I might be wrong here, which should immediately be added at least on top.
    That price and PSU no included???? EVGA Hadron Air used to cost $150 but included a Gold efficiency custom form factor 500W PSU.
    No filters included with that price? Are you really expecting us to buy them separate after spending that much money on the case?
    I'll give you at least +1 on the interior painted black. Keep that.
    You know it won't be long before other companies release similar cases, so just as an advise review my points carefully.
  37. Lazer1337
    Lazer1337 Limp Gawd
    249
    Feb 1, 2016
    Then look for another case? Not everyone is going to like it. Dan doesn't have to sell this case, he could of made one for himself and not shared it with us. You're welcome to make your own more efficient and less expensive case.
  38. dondan
    dondan [H]ard|Gawd
    1,741
    Apr 15, 2013
    Kalaminator
    The difference between me and EVGA is a capital of millions of Euro. So if they develop/build a case they build not 500 they build 5000+. Furthermore they made the Hadron out of 0.8mm thin steel and plastic. This materials are very sheep and does not look really High-End.
    The A4-SFX is made out 1.5mm brushed aluminum. So if you look for similar cases from LianLi that have small quantities and a riser e.g. the PCO5 they also cost 200€+.In the crowdfunding campaign I will add a chart so everybody can see what items have an influence on the price.
    So you see the price is high because:
    • low quantities
    • premium materials
    • premium manufacturer
    • very expansive riser cable that has the best quality on the market
    So you have to decide for yourself if you like to support me to get a very unique product that will not be seen from any other case manufacturer in near future. The reason is simple: Because of the need of high-end risers the profit for them would be too low.
    About cooling: Please read the case reviews or the A4-SFX or look at my results. There is no need of case fans because the static air pressure and the physical law the hot air rises is enough. I know it is hard to believe but the concept of the A4-SFX is so unique that you can't map your experience of the cooldesign of classical cases like the Hadron to the A4-SFX.
    jb1, babadook and xinux like this.
  39. busterben
    busterben n00b
    51
    Jun 8, 2012
    why do you need to know his age.
  40. raazman
    raazman [H]Lite
    126
    Jan 30, 2016
    Kalaminator, it seems like you are out of touch with reality. Dondan is not a billion dollar company. He does not have the luxury that big established companies do. Why don't you do your own research and look into how much it would cost to make a custom case and produce it as an indie.
    And please be professional, there is no reason to attack anyone while you seem to have the wrong impression on how this works. There are many obstacles and premiums to pay. If that's not for you then there are other cases out there.
