TSS Modder
- Jun 29, 2004
im probably going to be using some sort of dampening material when i build my new rig w/in the next 6 months.
should i buy commercial equipment (such as this: http://www.frozencpu.com/noi-02.html) or can i just use cardboard?
im already running farther into my budget than id like, and im trying to efficiently cut corners.
my goal is to build a silent/extremely quiet PC, and some sort of noise dampening material would aid me. id be sticking this on the side panel, in the drive bays (to reduce vibration), and on the screws of the fans (to also reduce vibration).
the question is would cardboard be effective enough, or do i actually need to buy a commercial product to do what i need it to do? cost effective is great, but silence is my main priority.
