damned cpu fan
keimigca
Great just started building the new pc and the damned cpu fan wont spin. So now I get to RMA it back to newegg and wait however long it will take to get the new one here before I get to play with the new pc. Blast I should have got a retail cpu instead of oem, at least then I could hook up the stock HSF and get the rig going. By the way it was an artic cooling 64 that was crap on arrival.
chris
IMO you should always spring that bit extra for the retail cause it has a longer warranty and comes with a cooler for not that much more. Also, those arctic thingies are a bit....well you know now :p. I'd buy a zalman if you want quiet, and its only a tad more.
If youve got a spare 80mm fan and havent already sent that hsf away just rip old fan off and stick new one on and plug it into the mobo header, simple :)
