Damn You Bun-Bun!
Buckus
How can Bun-Bun and his/her one processor compete with my dual 2.0 GHz boxes folding? Even running a hyper-threaded 3.2Ghz P4, I don't think he could keep up with a combination Athlon64 3200+ and Athlon XP 2400+, both running 24/7.
If anyone knows the answer, or if Bun-Bun wants to tell me his setup, I welcome it.
Also, does anyone who's running a headless/diskless folding farm know, does that count as one processor for each mobo/CPU, or one processor for each server? Maybe that's how Bun-Bun does it!
He/she could have an overclocked proc. running dual instances. Are you using all the tags?
Hmmm...no overclocking at all. I run the graphical clients. It runs all the time without having that darned extra window open at the bottom of the screen. Is there a way to run the console client without it opening a window on the taskbar? Possibly as a service?
Elektronik... Huh. Why would he want to run F@H3? Buckus, you can make the console version invisible by running it as a scheduled task in windows. Set it to not turn off after 72hrs or whatever the limit is in the advanced options. And add the -advmethods and -forceSSE to the tagline. Before I meant Bun-Bun might be running a overclocked proc 3.4-4.0+Ghz plus dual instances would get him a lot more points than you, probably.
Bun-Bun are you there?
Well, I am going to get my old Duron 1.0Ghz online and folding/print server in a week or two, so I should be able to get past Bun-Bun then.
Vengeance is mine!
Yay, vengeance.:)
Can you overclock your AMDs? That would at more power.
Yay, vengeance.:)
I've gotten my Athlon64 to 2.2GHz before, but decided to scale it back to OEM in the interests of longetivity/heat issues.
