I have a Sapphire 6950 2gb with unlocked shaders I run it at 900mhz (Core) 1430mhz (Mem) is what I found to be relatively stable...however, I neglected the Power control +20%!!!! I also just ran furmark on the card without power increase for the last hour! And I've gamed over 50+ hours on it this past month without the increase.
Do you think this damaged my card???
I don't really see signs of damage when I use it, I was curious because it would render things really weird in Witcher 2 if i overclocked the core any higher than it was already (like the ground would suddenly permanently rise up to neck level after 5-10 minutes of gameplay).
Are there any signs of damage to look out for or that are classic of this type of error?
