Hey guys, I'm trying to plan out wiring my home.
I have ethernet ran throughout the house. 7 rooms in total all coming back to a control box in a storage room.
In that room I will have my cable modem, a dd-wrt router, and a D-Link DGS-2208 unmanaged switch.
My plan is to have the switch plug into the router and then have all the room ethernet wires plug into the switch.
My dilema is that I need two connections in the family room and master bed room where I will have both an HTPC and an Xbox.
Can I place another switch in each room to share the ethernet wire? I currently have a EZ500-s that I would like to use, I would just need to buy one more small switch for the 2nd room.
Are there any problems with my idea?
Thank you
Thank you
