I've been watching my UV cathodes over a month or so. Most of them seem to be working great, while (2) 4inch tubes seem to bounce between a light-violet color and most of the time a pretty dark dark purple. Also when i power on the system after being shut off for sometime the lights i see take a few seconds (maybe 30 or so) to reach their normal brightness. not sure if that is normal or not.
My real main concern is the daisy chaining of power im doing. If you take a look at the following you can get a good idea
You can kind of see at the top by the CD-drives, I have 1 lead coming from the PSU powering both dvd drives and then using an T extender that came with the psu, i connected it to one inverter. Its been awhile since i put the machine together and ive changed it a few times so what im trying to say is. I have 3 inverters in there and i believe i have 2 or maybe all of them hooked to the same lead using the pass-through they come with. What i want to know, is doing this allowing the lights not to reach their max brightness? I know ull get degradation of signal if you use extension cables with video, does the power work the same?
