DAG Size and Multiple instances?
note235
I've mined a lot of coins but not ethash before.
I was looking to mine different ethash coins but it says cannot allocate DAG file size. I upped my virtual memory but it seems the recommended amount is 16000 (only have available 8000).
Would the solution in this case be buying another pair of memory to be able to run multiple instances of ethash?
This is the rig I plan on doing that on:
win10
4GB ddr4
3x 1080 ti
2x 1070
Try a different miner maybe, although I'm not at all familiar with ethhash and if it even has any profit to be made or other gpu mining software.
Try Ethereum with Claymore to verify your cards are all running correctly.
