Hi there,
Sorry to ask this. I'd normally just try it & see, but this is a particularly long EIDE cable - it was £6 ($12) and I probably won't be able to get a replacement for days if I bork it up.
Anyway, this cable has the regular configuration of connectors on it - one at one end for the m/board and two close together at the other end for the drives.
Since I only need to connect one drive to this cable, and space is limited in this box, can I safely cut the end off this cable & use only the middle connector?
IE:
Currently the cable looks like this:
Can I make it like this?
(where --- is the ribbon cable and || is the connector)
I just have this nervous feeling in my stomach (or maybe that's the apple pie my mom was just feeding me during my regular Sunday visit) that if I don't ask & make an idiot of myself I'll find that cutting the end off will have some unexpected effect on communications with the remaining drive connector.
Answers like "yes, I do this all the time" or "yes, it's in the specification" would be more reassuring than just "yes, you idiot"
Thanks,
Stroller.
IE:
Thanks,
Stroller.
