Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
32bit drivers cannot be installed on 64bit Windows. IIRC, Daemon Tools installs software drivers. They have a beta version at the moment that supports 64bit Windows, but don't ask for access (else they will ban you).
It should also be also noted that Daemon Tools is a very common cause of system instability and failures.
