DAEMON Tools Lite Alternative?
+1 for PowerISO
It's free to do almost everything. I use it to mount and burn ISO's, and erase rewritable disks.
Works perfectly in win 7 x64
http://poweriso.com/download.htm
Er, free? Taken from that site:
Free unregistered versions will allow you to evaluate the software for free to determine if it suits your needs. Click "Download" to download and install the software.
The unregistered version will display a dialog prompts you to register, and you can not create or edit image files greater than 300MB with the unregistered version. To remove these limitations, please register.
I've got nothing against PowerISO, but it's not free.
It's free to download and I said to do "almost everything". Everything except creating or editing image files bigger than 300mb... if the OP does not need to do that, then this is a fine solution.
