D975XBX2 problems with Quadcore...
Tengis
... we CANNOT get this thing to throttle the CPU fan speed with the temperature. The temperature reads zero in the bios and in any Windows utility. We have updated the bios and everything to try to fix the issue but no version of the bios will give us any CPU temperature over zero.
This thing is loud! :D
You probably could if you had a fan speed controller not built into the motherboard with a temp probe (that's how I control my case fans). But it should work without it. Did you ask Intel's support about it?
Intels support? On Intels site? Or are you saying I should call them?
