so i am building a system and bought my components, including a
BadAxe2
i got everything together, fired it up, and got a seemingly cyclic (not quite perfectly cyclical) clicking. i figured it had to be a fan.
unplugged all fans. (including cpu fan) - same clicking noise.
removed video card (passive anyways) - same clicking noise.
pulled power from all drives - same clicking noise.
so i am like, hmm... WTF!
i pull my crucial ram with the purty lights. - clicking noise GONE.
i then brilliantly conclude that i have noisy ram. is that even possible? i dunno, but the noise seemed to be gone. i didnt listen much past the error beeps.
so i got a replacement stick and dropped it in there. same clicking noise.
at this point, i am thoroughly confused. i need some help troubleshooting.
one of my concerns is that i may not have the power properly plugged into the motherboard.
i have two plugs from my seasonic 550 energy PS. one is the main motherboard connector. reading the limited engrish manual for the power supply, i conclude that i should also plug in a 4 pin (like what goes into a cd drive) plug into the motherboard as well. am i plugging too much power/not enough power into the motherboard?
i also need to plug in the pc into a surge strip and try a different outlet.
after that, i will be completely stumped.
final clues - the clicking starts immediately on power up. doesnt seem to change speed/frequency regardless of what i am doing.
if anyone thinks its helpful, i can try and take a decent recording with a good mic and post it up.
BadAxe2
