D845WNL-will it run 533 Processor
mnitetrain
Motherboard currently running 1.8 P4 at 400FSB. 400FSB appears max for this board. Thinking about upgrading processor to 2.53 with 533 FSB. If it runs, it won't be running at full potential (400 vs 533). Will it make much improvement or not worth effort?
Also appear to be voltage differences between the two processors- will the board self adjust volts-running latest bios P15.
Thanks for any info or advise.
Motherboard - what manufacturer?
Did you check Intel for CPU, chipset and motherboard tests and compatibility lists?
I don't know what the prices of either board, nor P4 2.53GHz/533FSB are but, the 533FSB is limiting in some areas (400? Fugiddaboutit!). :D
This link may not give you the comparison chart I made, but you can find the P4 selections you're interested in, and the results will show compatible chipsets and mobos.
Since October, I've been slowly upgrading from a P4 2.53GHz/533FSB CPU on an ASUS P4B533E mobo to what's in my sig. The difference between systems is amazing! Even considering I went through an interim system of my C2D E6400@2.13 on an ASUS P5PE-VM mobo (800MHz FSB/1066MHz w/AGP video card) using 2GB PC-3200/DDR-400 memory, an AGP (gF6600 GTOC), and two PATA IDE hdds. Save your money for a couple months and you could be running an E4300/E4350 powered system.
TonyB thanks for taking the time to look. Pretty much what I concluded. Was worth a couple thoughts.
What do the release notes of the bios revisions say? I know the 845PE chipset supported both the 400 and 533mhz bus speed processors, but it was a revision of a previous 845 chipset. I don't remember how many 845 revisions there were or what the older chipsets supported.
I know the P4B533E I had used the 845G and didn't have any problem with PC-3200/DDR-400 RAM, but the board ran a 533FSB. I don't imagine the P4 2.53/512kb L2 would balk at the 400 FSB on the board mnitetrain mentioned.
mnitetrain - Have you ever heard of using an old computer like yours as the gateway/proxy for a home network? I read a blog once about that; shielding the other machines on the network with the old one. As long as the old computer can sustain transfer rates commensurate with your internet connection, there shouldn't be any slowdown/bottleneck. Just a thought!
Personally, I'm drawn to the idea of turning an old computer into a toaster. Everybody's seen it the other way around. :p
bis luego!
TB
Going to have to dig some to verify 845 chip and V.
??the 400 FSB on this D845WNL board is based on 100mhz, the 533l would be underclocked (is that right term in this case) from 133 to 100.
The D845WNL is wife's box for her business just basiclly looking to extend it's life for short money.
