d-tek uv dye blue=orange ???
game14
i got me some D-tek UV dye visible blue . I added some to my water till i got a nice deep blue color so far i was quite happy ....till i turned on the UV CCFL .... surprise , WTF, it was glowing orange !!!! :eek::eek:
I thought it was suposed to glow blue ... !!!
http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=45 ,it clearly says blue under UV light !!!
Is that normal that it is orange under UV light ???
$ 10 dye that is not the color its suposed to be - complete rip off !!! :mad::mad::mad:
You musta got a bad batch.
the Clear UV blue stuff starts out glowing bright yellow, but gets bluer and bluer in a higher concentration.
so thats normal ??? great , cant even rma it .
Now i have to drain my loop again and get some new tubing again .
Its really hard to get a nice color .:(
Correct me if I'm wrong but I believe he said that it's orange because there's not much of it in the loop. This was in reference to the clear UV blue, but i'd imagine it applies to this as well.
Why not contact D-tek? if the product doesnt work as advertised you should be able to get a refund or replacement.
At least attempt to resolve the problem before you start over.
i poured in half the bottle ....you think thats not enough ???
got the dye from jab-tech , but anyways could contact d-tek , see what happends .
I'd imagine jab-tech will either refund or send you a good bottle, I don't think it would be worth the $5 they pay for it to give you much of a hassle. If nothing else you can get the problem corrected so others don't end up with shitty dye.
