Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Does anyone know what is the correct orientation for the Quad Core Nozzle when used in the D-Tek Fuzion V2 CPU block? There is no information on this even on the D-Tek site. Am I the only one wondering about this???
I have the Fuzion V1 with the quad nozzles and I think I have it so the openings are in the same direction as the text on IHS (as opposed to above and below the text). I guess this is harder to describe with words than I thought...
The cores are laid horizontally if you have the CPU rotated such that you can read the front text. I'd imagine that the holes of the midplate would be positioned such that they would inject water directly over the cores. This would orient them horizontal as well, as opposed to on the bottom and top (when looking straight down).
Sorry, I don't have the privilege to attach pics. But basically, my understanding from the above is that the two openings of the nozzle should be aligned with the two sides of a Quad Core CPU; i.e. one for each side. Since the cores are arranged horizontally, the two openings should also be horizontal.
