D-Tek kit...Good cooling for cheap
SpoogeMonkey
I thought I would point out this d-tek customs kit for people looking for a low cost jump into water cooling.
This kit is almost identical to what I pieced together 2 years ago, and is now a lot less. It comes with Cathars original White Water block, a single 120mm rad, 12v pump, res, and all hardware.
The only difference from what I had, is I went with the old Hydor 30 pump and a clear 5 1/4 bay res. It worked great on my old axp 2400+
If you look on dteks' front page, they have a 10% discount on orders over $100, and 15% off $200. For $153 I would recommend this over lesser kits like the Big Water, Aquarius etc.
Looks like a great starter kit with plenty of room to expand. Their options look a little pricey though...........but most E-tailers are that wiy with kit options.............. :eek:
I believe that is not the original White Water block, but D-Tek's version of the White Water.
That is a very good performing configuration for the money. I have two and loved them.
