D-Link dir-825 / intel wifi 4965agn problem
vizx
i just replaced an old belkin g router with a d-link dir-825 extreme n dual-band router...i managed to get the desktop connected to the internet using a d-link dwa-552 pci adapter (after updating using the atheros version driver, the included software manager/driver on the cd was a pain-in-the-a$$)...
the macbook pro also connects to the router and the internet...as does the wii and the ps3...using WPA2 security...
the vaio laptop, with vista business 32-bit and an intel wifi 4965agn adapter will not connect to either the router (192.168.0.1) or the internet in a browser window...
i updated the driver to the latest version...
the wireless network shows up, but when i try to connect it says "local access only"...in the vista diagnostic window it says "can't connect to primary dns server" (192.168.0.1)
i set up the router with this same laptop using a wired connection and the d-link set-up wizard, and i got an internet connection then...it just won't connect wirelessly...
of course i reset the router and the cable modem (time warner/roadrunner)...
is it an ip address problem? if so, how do i solve it?
thanks for any ideas...
