I am trying to find a good computer fan for a scientific product I am developing. I am trying to fit a fan inside of round vacumm tubing, or to get a square fan with an adapter that allows it to attach to vacumm tubing. The internal tubing diameter is 2.5 inches (~60mm). The fan with the highest cfm and lowest vibration would be the best.
If I am being too specific, essentially I am looking for a (preferably) round fan with a high cfm and low vibration.
Any help at all would be appreciated.
Thanks,
Mike
Thanks,
Mike
