scharfshutze009
- May 22, 2010
CyberPower OR1500LCDRM1U 1500 VA 900 Watts 4 x 5-15R Battery & Surge 2 x 5-15R S
Learn more about the CyberPower OR1500LCDRM1U
Model
Brand
CyberPower
Model
OR1500LCDRM1U
Input
Input Voltage Range
90 - 140 Vac
Input Frequency
60 Hz +/- 3 Hz
Input Connection
NEMA 5-15P
Output
VA Rating
1500 VA
Watts
900 Watts
Output Voltage
120 V +/- 10%
Output Frequency
60 Hz +/- 1%
Outlets
2 x 5-15R Surge-Only
Outlet Type
NEMA 5-15R
Battery
Battery Run Time
Runtime at Half Load: 11 minutes
Runtime at Full Load: 2 minutes
Battery Recharge Time
8 Hour(s)
Battery Replaceable
RB0690X4
Details
Alarms
On Battery, Low Battery, Overload
Interface Port
USB, Serial
Approvals
UL1778, cUL 107.1, FCC DOC Class B
Rackmountable
1U
Surge Protection
Data Line Protection
Phone RJ11 / Ethernet RJ45: 1-In, 1-Out (Combo)
Surge Energy Rating
1,030 Joules
Protection
Internal Circuitry Limiting / Circuit Breaker
Features
Features
Intelligent LCD Diagnostic Display: The innovative front panel LCD can be used to display detailed information on the UPS status and current power conditions. The LCD displays 11 different diagnostics: AVR Status, Estimated Runtime, Battery Capacity, Load Level, Input & Output Voltage Level, Output Frequency, On-Battery, Overload, Fault, Silent Mode, and more.
Automatic Voltage Regulation (AVR) - AVR takes irregular AC power and converts it into a consistent Sinewave so sensitive electronic equipment can achieve its optimal performance. This “Boost/Buck” topology will both increase low voltages and decrease high voltages, without switching to battery-mode. This conserves battery life, and delivers a more stable signal to your connected equipment.
Microprocessor-based Digital Control - Digital routing is maintained through a network of integrated circuitry and discrete values used for internal system processing, which significantly increases efficiency and responsiveness.
EMI/RFI - Provides shielding against electromagnetic interference & radio frequency signals. Most commonly, this is used to prevent line noise or “humming” that occurs over telephone lines or stereo electronics.
USB Connectivity - An HID-compliant USB port enables full integration with built-in power management and auto shutdown features of Windows, Linux, and Mac OS X.
Metal Housing – Rigid metal construction allows for placement in areas with a demanding environment.
Audible Alarms - Audible tones identify when the unit is running off battery power, unit overloads, and low battery.
Resettable Circuit Breaker - Convenient unit reset switch in case of an overload.
Dimensions & Weight
Dimensions
17.25" x 19.50" x 1.75"
Weight
45.60 lbs.
Plug Standards
Electrical Outlet Plug Type
Plug Type “A” (USA, Canada, Mexico, Japan)
https://www.ebay.com/itm/232713366397?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
Model
Brand
CyberPower
Model
OR1500LCDRM1U
Input
Input Voltage Range
90 - 140 Vac
Input Frequency
60 Hz +/- 3 Hz
Input Connection
NEMA 5-15P
Output
VA Rating
1500 VA
Watts
900 Watts
Output Voltage
120 V +/- 10%
Output Frequency
60 Hz +/- 1%
Outlets
Outlet Type
NEMA 5-15R
Battery
Battery Run Time
8 Hour(s)
Battery Replaceable
RB0690X4
Details
Alarms
Interface Port
USB, Serial
Approvals
Rackmountable
1U
Surge Protection
Surge Energy Rating
1,030 Joules
Protection
Features
Features
Dimensions & Weight
Dimensions
Weight
45.60 lbs.
Plug Standards
