Turned out well for my lanbox:
I did a 120x2 cut on my A05B with a nibbler without issue. I does take forever tho.
Re-enforced cut off wheels work perfect on cases.which bit is recommended to use with a dremel?
It cuts through metal.. it will cut through the tape as well.it will cut through tape right?
It cuts through metal.. it will cut through the tape as well.![]()
