ShaolinDragon said:Sounds pretty impractical. My suggestion, go with the dremel.
Tell me, what part ofXeRo_Dark said:btw...... is gi jesus smoking crack? yah use a tablesaw to cut a hole in something........... well .... ofcorse your trying to cut the pannel completly off instead of making a window in it![]()
did the thread starter make mention of cutting windows? I believe the thread title is "Cutting Aluminum," and that is is you who is smoking crack.PoW said:Im looking for some advice on how to cut perfectly straight edges on 1mm aluminum panels. I need to cut a perfectly straight line. Is there a attachment for a dremel that allows this to be performed easily?
Filing to the finished edge is the best way. I do like Qtip says and stay away from the line while cutting, and then file/sand to the line.Qtip42 said:Or do what I tend to do...Cut the line about 1/16 of an inch off from where you mark it. Then sand the rest down with a sander or file. I've got a 1" wide sander that takes stuff off pretty quick with 50 grit. You can use bigger ones but I hardly use it because I'm getting better at doing straight lines.
domoMKIV said:flex-shaft attachment.....will that fit on a generic dremel? i hate holding the ginormous dremel when im trying to get in small areas.
domoMKIV said:yeah i meant off-brand "dremel". but doesnt matter now, my gf picked up a 400XPR kit for me earlier today as an early xmas gift. this thing is sweet![]()
kuyaglen said:I actually recommend using the small circular saw blade attachment for something this size.
And just run it up against a piece of wood to get the straight lines.
altec said:thats my prob i don't have a steady hand to save my life i think its all the coffee and coca![]()
