I'm going to mount this:
on top of this:
and I was thinking of cutting the top with this:
It's a very nice 18V varible speed saw, specs are here:
http://www.ryobitools.com/index.php/catalog/tool/p520c/
I have no prior experience cutting acrylic and have no desire to screw up my new $250 case. The corded version of this saw has a "scrolling" blade option that this one doesn't, no idea what that's for. I'd _really_ like to buy the cordless version for this task if possible because it will be easier to justify the expense.
I will be practicing on scrap acrylic, no doubt. I also will be masking off my case as well as drilling pilot holes in all corners of where I plan to cut (which will most likely be a template made from the fan shoud for that radiator (i.e. the cuts will be basically 3 120mm squares).
My questions are:
1. Can the cordless version of this saw do this job effectively or would some other tool be more appropriate.
2. What do I need to know about blades and/or drill bits and/or speeds when cutting acrylic because I know you can wind up melting rather than cutting the stuff.
Any and all help will be greatly appreciated and my apologies if there is a post that addresses these exact things already, search was _not_ working for me and I didn't see anything in the first 5 or so pages.
TIA
on top of this:
My questions are:
TIA
