Sheldog23 said:I have heard this myth as well....
something about the WC. For example with at normal heatsink when you turn off your PC the heat continues to disapate throught the heatsink. but with WC the heat just heats up the water and sits there on the CPU, thereby shortening the life of the CPU.
I think the uncirculating water would slowly cool just as effectivly as the unfanned heatsink myself but have heard this said many times
ShepsCrook said:Actually, Technically your WC CPU... WILL heat up after the computer has been turned off. Why you might ask? For a brief period after your system is shut down, the water is no longer flowing which won't cool the CPU as well because the water at the CPU now sits and becomes heated up by the heat from the CPU. Thus not cooling the CPU. Once the CPU has cooled off on it's own from dissapating it's heat, the water will then keep the CPU mildly warm for a while after that, acting as a sort of liquid heating. The water heating the CPU is not so much a problem as it's not as hot as the CPU had once been.
Anyways. This will not ruin your processors lifespan.
OCing a processor with improper cooling WILL put your processor to a slow death. But that's why you come here and ask for help so that people can inform you on what is the best cooling for what you are looking to do.![]()
ShepsCrook said:You didn't read my statement. I said when the computer is shut down and there is no waterflow. Since there is no waterflow to move cool water onto the waterblock to cool the CPU, there's a brief bit that the CPU raises in temperature.
It's just because there is no cooling going on.
No need to become rude about it either "buddy"
MAB said:Is it true that overclocking could cut your computer's life in half??
Sheldog23 said:For the record I would just like to say I never meant to Imply that the CPU "heated up" after it was turned off with WC, or got anywhere near the temps of powered on temps.
