stelsevo
In connection with the problem of ordering the DC-ATX G-Unique, I decided to expand the range of enclosures with internal power supplies. I also think that many people will like the idea of installing a more powerful video card than in our previous mini-cases, for example ZOTAC GTX 1080 Mini with a length of 211mm. Also in this case will fit a power supply measuring 190 x 81.5 x 40.5 mm for example the Seasonic SS-350M1U 350W. It is interesting to hear your opinion.
Specs:
- Volume: 5.24L (220mm x 227mm x 105mm)
- Production: ESI METAL factory (video), swiss solutions «Bystronic»
- Material: 1.5mm Aluminium, Powder Coating
- GPU: length <211mm, height <132mm (ZOTAC GTX 1080 Mini compatible)
- CPU Cooler: up to 45mm (Noctua L9i recommended)
- RAM: up to 45 mm
- Storage: M.2 and 1x2.5" SSD
- PSU: Flex ATX 1U Mini-ITX (Seasonic SSP-300SUG, FSP 400W, Athena Power 400W, FSP 500W Platinum etc)
- Price: $180 (Case + PCiIe riser + Worldwide Shipping)
MSI GeForce GTX 1060 6G OC 188mm
Zotac GeForce GTX 1070 Mini 210mm
ZOTAC GeForce® GTX 1080 Mini 211mm
Asus PCI-Ex Radeon RX 460 ROG Strix 4GB 194mm
ASUS PH-GTX1050TI-4G 192mm
I dunno, looks like the 1080 will be dumping a lot of heat directly onto the 2.5" drive…
опустить максимально в низ?
Lower as much as possible in the bottom?
I really like the internal power supply and the space for a 2.5 inch drive. Also, I wonder if there would be room for a 92mm fan in the front below the 2.5 inch drive?
There seems to be no point in developing this topic further. Judging by the way people react. ((
