Customize UAC in Vista
recurr
There are some UAC options in the Local Policy if you don't want to turn UAC off completely. I found out about them from the Vista Guide at http://www.tweakguides.com/TGTC.html.
Start, Run, secpol.msc
Local Policies, Security Options
User Account Control: Admin Approval Mode for the Built-in Administrator account Disabled
User Account Control: Behavior of the elevation prompt for administrators in Admin Approval Mode Prompt for consent
User Account Control: Behavior of the elevation prompt for standard users Prompt for credentials
User Account Control: Detect application installations and prompt for elevation Enabled
User Account Control: Only elevate executables that are signed and validated Disabled
User Account Control: Only elevate UIAccess applications that are installed in secure locations Enabled
User Account Control: Run all administrators in Admin Approval Mode Enabled
User Account Control: Switch to the secure desktop when prompting for elevation Enabled
User Account Control: Virtualize file and registry write failures to per-user locations Enabled
Sorry about the repost, but I've read posts saying you can only have UAC completely off or on. I didn't know about these options.
Update: Home Premium users can use the registry. http://www.tweakvista.eu/show_tweak.php?tweak=164
I found this helpful, I've got that page bookmarked now for when I install Vista again once my stuff comes in, from the egg and from RMA w/ BFG.
When I type secpol.msc I get a message that Windows can't find it. This info is useful for those with Vista Business and Ultimate and that is why you see posts saying UAC is either on or off. Most of us have Home Premium. Thanks anyway.
i turned off "switch to secure desktop" because that was the only truly annoying thing about UAC. But, what do they mean by secure desktop? Is it less secure to turn off secure desktop?
edit: ah
Displaying User Account Control elevation dialogs on the Secure Desktop helps protect the user from unknowingly allowing a program to run with elevated privileges without their consent. Without this protection, it is much easier to create malware that tricks the user into approving an elevation request prompt that they really wanted to deny. The Secure Desktop helps protect against this because other software running on the machine is blocked from interacting with the user's interface.
so it's to keep me from being duped into clicking continue, but i still don't get it
it prevents anything else from running when it opens the secure desktop. if you notice, you can't do anything else while that prompt is up so disabling it is basically taking the most secure part of it out.
as for the whole guide...i recommend going thru and doing a lot of the tweaks. its a very informative guide. i ended up doing a reformat just to get a fresh start and do all the shit i've learned in the past 2 months. i've spent the last couple hours tweaking everything. bout to do the pagefile tweak right now tho :)
Sorry, try this.
Since Domain Join and Group Policy support is not available in Windows Home and Windows Home Premium you are forced to disable User Account Control through the registry. Because Domain Join and Group Policy support is set through secpol.msc, which is not available in Windows Vista Home and Windows Vista Home Premium you are bound to set User Account Control through the registry key's listed below.
Code:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System]
"ConsentPromptBehaviorAdmin"=dword:00000000
"ConsentPromptBehaviorUser"=dword:00000001
"EnableInstallerDetection"=dword:00000001
"EnableLUA"=dword:00000001
"EnableSecureUIAPaths"=dword:00000001
"EnableVirtualization"=dword:00000001
"PromptOnSecureDesktop"=dword:00000000
"ValidateAdminCodeSignatures"=dword:00000000
"FilterAdministratorToken"=dword:00000000
