Custom resolution on VGA conenction. ?
Booker
Hi,
I have a monitor LCD with dvi.
And a tv plasma, lg60 with native resolution at 1024x76 via VGA connection.
When I used on my tv at 1024x768 the aspect ratio is 4:3 so all
My video/games are streched.
I need to know if is posible to do a custom resolution with nvidia on VGA conection, or this will only work on dvi conection?
Thanks
I would think you should be able to.
I have not seen any plasma TV's with a 4:3 aspect ratio. Can you double check that it is 1024x768?
all 720p plasmas are 1024x768 because their have rectangular pixels instead of square.
Anyways i downgrade drives and it`s working fine :)
any idea why custom resolutions are not allowed on Games?
I can use custom resolution on Desktop using Nvidia panel control.
But when i run a game, custom resolution are not listed.
Any idea?
Some games are awkward about supporting non standard (and even some standard) resolutions.
Check the config files for the game and see if you can manually change the resolution.
