Custom res on 7900GS
synaps3
I recently got a 32" LCD TV that has a native res of 1366 x 768. My 7900GS won't output the resolution, so I have been running in 1280x720 with a black border around the edges. In the NVIDIA utility, I tried to enter 1366 x 768 as a custom resolution. When I click add, it says "The custom resolution input is invalid." How can I get my computer to output 1366x768 to use the whole panel?
Thanks.
how big are the bars.. have you tried using adjusting the overscan/underscan options? if they still have those options..
Thanks.
Are you using DVI or analog? I had that exact same issue when I conencted my Dell 2407 via DVI, but then tried using analog, and it worked... I then put back the DVI connector and the new res worked. Its worth a try.
tHe_BiNk said:
First hit in google, this is too easy, do some research first before you ask a very simple question which has been ask a 1000x before, and for which you can find the answer within 1 sec on google.
http://www.nvidia.com/object/custom_resolutions.html
:D
That's the first thing I tried. Didn't work.
I'll try the powerstrip thing. Thanks for the link.
Bobby, I will try looking at and messing with over/underscan if powerstrip does't work.
retro, it is through analog.
