Custom or a kit for Antec Aria?
Zallek
I've seen people using that GlobalWIN SilentStream WC kit in Arias and such, but the reviews pretty much say decent air is a lot better, and cheaper.. Anyone know of a decent kit that you can fit into an Antec Aria? Or recommend some pieces for a DIY?
-Edit-
Almost forgot.. I guess the cpu block would need to be for a socket a, and possibly would need a gpu block that'll fit a 9800pro (not entirely sold on the gpu block though if I do it).
-Edit 2-
Found the Coolermaster Aquagate R80 and R120 mini kit things, they seem to be better than the GlobalWIN, and roughly the same price.. Just need to measure if I can squeeze the rad and the fan in on the inside, because I know I can fit the 120s if I cut into the hdd/optical rack..
