Custom Monster Energy case
RWTF3131
I'm going to be creating a custom monster energy case, this is my first case modding ever, and i hope it turns out good, btw what kind of paint do you guys recommend for plastic(front) and metals(side panals):D also whats the best way of cutting the logo out of the sidepanal?:confused:
pics comming soon.
Auto body paint works best on metals (and I think plastic as well, but I am probably wrong)
Cutting logo? Dremel + reinforced cutting disks
with the crooked edges of the Monster logo, a dremel would be a very tedious process, but probably the most accurate. Other than that, look for a laser cutter in your area and buck up the $75-100, if they will even do a trademarked logo.
Are you going for the Green "Energy" look, or one of the other colors? I thought a Monster Assault case would look cool, but I haven't the workspace or the patience to do it the justice it deserves. The camo paint with a red backlight M logo in the side would be killer.
Here is the case that i'm using pretty simple, the front middle is gonna be green, and the reast black, and two fans at the top with green LEDs:D
URL=http://img255.imageshack.us/my.php?image=picture024aa2.jpg]
[/URL]
Hey, I have one of those cases :D. Definitely not an HP case, it's just a cheap OEM model from some random manufacturer.
