the other thing you should check is your temps, who cares if the flow is low if temps are good and your noise level with pump at 100% is okYeah the blocks are RAM blocks, EKWB recommended them. I'll take a look at what you recommended!
If it were me, I'd pull the RAM blocks. I've never seen a case where they were actually needed, regardless of RAM overclock.
After that, if you're concerned with flow, go to a parallel block for your GPUs vice serial. That should reduce the restriction (and increase flow) without really impacting GPU temps at all.
Yeah, I hear you. Maybe they were just trying to sell me on as much as they could =)
Anyone know if it's possible to convert a EK-FC Terminal DUAL Serial to Parallel by just swapping the top port? From their manual it looks like it but I don't understand why they'd have two different terminals if you can just swap the port.
They have different internal routing, so no you can't. You CAN just use two short lengths of tubing to get the same effect, but it won't look as nice.
Out of curiousity, did you end up using or pulling the ram blocks? If you pulled them did you notice a bump in your flow rate?
