Ok I am in need of a small case that I can move my WHS build into. My current build is loud and not as expandable as I like. Its also bigger then I would like it as well.
I have searched and searched, but I cannot find anything that even remotely comes close to my vision of the ultimate home server case. Here is my vision which I think would be a great WHS case.
This case should have 6-10 hard drive mounts, facing sideways just like the NZXT Alpha. These hard drive mounts should extend all the way from the bottom of the case to the top. Either have no optical or a single optical.
The hard drives should be hot-swap, or at least be able to slide in and out with some type of sled system. Also, there should be fans all on the front of the case, much like the Antec 900. The front of the case should be mesh to allow as much airflow as possible.
It should have a small PSU (around 500 watt) with enough sata connectors. I am thinking it should be mATX just to save on space.
Also, the front bezel around the top (if there is no optical) should have an LCD readout of temps, cpu utilization, network use, and etc.
After all this, you can see why there is no case like this on the market. Home servers are currently a small niche, and I do not think any of the case manufacturers think this would profit.
Now, I want to make this case from scratch. For simplicity and cost reasons, I think the best idea would to use wood. It is easy to work with, easy to shape, and is cheap compared to any other material. It is also non-conductive and takes paint really well. I also have many tools to work with it.
Wood can be used for the case and HDD cage. For the hot-swap, I found these units which are quite cheap and I can buy only as many as I need. The tricky part is cutting the wood so that the modules are EXACTLY in the right location or else it fails. http://www.aerocooler.com/shop.cart?action=ITEM&prod_id=CASSCP5
I will use some nice very low-rpm 120 mm fans (600-1000) to noise down but airflow up.
As far as the LCD, besides going with Alphacool, are there any smaller cheaper units instead? Not really a big deal with the case, but if I can source this cheap enough, its a definate addition.
I will gladly take any advice, suggestions, and ideas for this. I do not know when I will begin on this, so this may take some time to finish.
