Custom Fit Mobos?
Megalomaniac
just thinking out loud.
Its kinda funny the amount of things that manufacturers put on the mobo that is never used by the consumer.
I am sure that there are a few people who have the perfect mobo and were able to utilize almost everything on it.
But half the time i see a mobo and i think to myself: This is such overkill.
I was reading the review of the new (and the last) Uli chip (at Toms, yeah yeah i know) and read this : the M1697 has a total of eight rather than ten USB 2.0 ports...
do you care? i know i dont. I rarely use more than 4.
I am sure that tere are people who use that many, but its just funny that it even deserves a line.
The next one is a bit more dramatic: and it comes with only a 100 Mbit Ethernet controller. Gigabit Ethernet has to be added via companion chips using PCI Express, since this requires some additional silicon real estate.
That might actually deserve a line. Because when I have fiber running straight to my house, i will probably use that gygabit connection.
(light sarcasm there)
Have your ever seen a mobo that just creamed to you L this is perfect. It fits like a glove!?
just random thoughts.
8 USB ports are there to suit your needs, even if you don't use them.
Keyboard
Mouse
Printer
Scanner
Webcam
Joystick
Flashdrive in the front
Camera cable
iPod
There are a LOT of things people use USB for.
As for the 1Gbit ethernet connection, obviously you do not have an OC-192 hooked up to your house, but ethernet ports capable of those speeds are for PC to PC transfers or just any transfer over a network. Isn't 100Mbit enough for this? No! :) But seriously, moving GBs of files from one PC to another over a 100Mbit connection takes some time.
The problem is though that manufacturers can't suit everyone's needs. They can try and suit needs of gamers, or office workers, or for whatever other group, but it would be silly not to put all those features onto a board simply because you don't know who will be using it.
A board lacking in less than 10 usb ports is no big deal imho. An add on card is cheap enough. And here is my sarcasm for the day, I moved a 250MB file from one rig to the next in 23 seconds the other day. Now my rig had gigabit, but the other only 10/100. Is the world moving so fast that transfering a gig of info in just over a minute is too slow?
^ yes
'_'
i havent found a mobo to suit my needs yet :(
they just dont understand me! :cry:
Then I guess I'm too old. I remember it took 45 minutes to install Parsec off a cassette drive.
