- Jun 28, 2004
So we have a windows XP pro machine that runs as a very crappy file server. It has 4 different license server systems on it.
Specs are as follows:
Pentium 4 3.0Ghz 2MB cache 800mhz FSB
2GB of Ram, never even uses a gig of it.
Its I/O performance is terrible at 23MBps though its cheap Adaptec controller via RAID 1.
It does not run with any permissions or file management at the moment.
We slam into the 10 concurrent user limit multiple times daily.
It runs CVSNT for computer code compiling and sits a 100% CPU use for minutes at a time, at which all I/O in and out of the machine halts momentarily.
We moved most of the data out of that computer and over to our secured 2003 server (which IS a beastly fileserver)
So what I want to do is as follows:
purchase a HP proliant ML150 G6 starting out with a single 2Ghz Xeon quad core and 8GB of EEC Ram.
I want to add an Adaptec 3405 SAS card 4x 1TB SAS HD's and install ESXi.
The RAID controller on the ML150 motherboard is a softRAID controller that will not be recognized by ESXi as a RAID 5 controller, I 've been told its a really a re-badged ICH10 Intel controller.
I'm thinking about partitioning the RAID 5 array into several partitions.
What do you all think?
- Partition 1 C:\ for Windows 2008 R2 (FileServer/ direct Connect/)
- Partition 2 D:\ Data Store for Employee use
- Partition 3 E:\ VMD storage
- Partition 4 C:\ for Windows 2008 SBS (AD, DHCP)
- Partition 5 D:\ Databases (very little use) small data sets
- Partition 6: C:\ Ubuntu or Windows XP (Tinkering)
- Partition 7 D:\ as needed
