I have always thought that computer speakers were specially designed for computers and you should only use computer speakers. Well I have owned the Z-680 5.1 for a very long time.
I was thinking about doing a custom computer speaker setup. I was thinking about a 5.1 setup. I would like to purchase 6 speakers + external Amp + External Subwoofer. Maybe my budget is say $1000 to $2000 max.
Here are some questions if anyone can answer to help me understand this better.
1) Does anybody know how a custom setup will sound compared to my Z-680's?
2) Is there any drawbacks to purchasing non-computer speakers? shielding?
3) IS there currently a best bang for your buck custom computer speakers, amp, or external subwoofer? LIke do many people usually choose certain speakers for computer setups?
4) Why is it that most people will spend big on TV / home theater speakers but will only buy cheap 5.1 computer speaker sets?
5) Can someone recommend a decent setup for custom computer speakers?
6) SHould I consider going larger or smaller for computer speakers?
7) Are their any issues with having larger speakers close to you, as you would probably have them next to where you sit.
8) Am I crazy and alone in that I prefer having external speakers than using head phones for gaming?
9) anything else relevant please give some input.
