Custom Computer Problem
Hey all,
I built a system about two months ago and it had been running great until Jan. 29th when I rebooted it. When the system was posting I got an error: windows/system32 file is corrupt! :mad: I was going to do a windows repair, but then after another restart, posting came up with another message: partition table not found! WHAT! :eek:
Some how I lost my windows installation and it was wipped from my hard drive. Tried reinstalling windows but after formatting the disk for a new partition I got a message: partition cannot be completed, drive is corrupt. So, I went ahead and sent my hard drive back to Western Digital and I got a new drive yesterday.
I hooked up the new hardrive and loaded the Nvidia SATA controllers and proceeded to the windows partition formating. I thought everything would go smooth, but when 100% complete with the partition formatting I got this: partition could not be completed, drive may be damaged. :confused:
I am very confused on what is wrong? I was wondering if it was the Nvidia SATA controller or do I need to restore the defaults in my BIOS since they are tweaked for overclocking performance? Let me know if anyone has any ideas.
System Specs: Abit AN8, AMD 3500, XFX 6800GS, 1GB of Corsair, WD 80GB Hard drive, Antec 500w PS.
Thanks.
If you've over clocked your system, that could be what caused all the troubles.
Make sure you return your system to stock settings before moving forward.
1) Reset Your CMOS.
2) LEAVE YOUR SETTINGS ALONE IF YOU DO NOT KNOW HOW TO CORRECTLY USE THEM
3) Wipe HDD
4) Install Windows
Report back with the conclusion.
I reset the BIOS setting back to optimal default settings and gave the windows installation a try and it worked. Thanks for the advice. It had never occured to me that I still had the BIOS on OC mode. :p
My rig is back in shape. Thanks.
