Originally posted by CrimandEvil
It looks like you could drill out the rivets and make your own mount using a cut aluminum sheet like how you have it. That way you don't have to worry about the grills.
Originally posted by Xeese
I have a couple different shaped 1U PSU's that might work in there. One standard form factor, one a bit smaller in shape. I will get you dimensions on Saturday.
Yeah, I was think that a 1U or even a 2U would fit nicely like that though. Is it me or does it look like this would fit? It's a 2U and I'm sure that a 1U would fit like that.Originally posted by Xeese
From having done a G4 mod - there are some real height concerns with a standard ATX PSU above the I/O areas. I was able to get an SLK-800 in with a low profile 70mm fan, but it still didn't have a lot of clearance.
Originally posted by Zeratul1320
do you really need all of the PCI slots? If you dont then why not cut the bottom ones off and slide the whole tray over to clear more room for the PSU
Aqua_Geek said:SketchUp - you can get a demo here.
