Curve Optimizer and 5800x3d
Light1984
Hey all. I recent installed Ryzen Master to play around with it and noticed that the CO tab is not available and it indicates that CO is not enabled for me. However, in bios (v4805 on Asus CH8 DH) I have it enabled with -20 all core offset. Is this just a bug, or something else? Any other programs you can recommend to verify in Windows that CO is working or not?
Are you sure you're setting up PBO in the correct place? If you're in the AI Overclocking tab or whatever they call it, the PBO section there literally doesn't do anything.
Advanced > Scroll down to AMD Overclocking then set it up in there.
This is a classic Asus thing. Two PBO sections, one does nothing. (this is all in the BIOS BTW)
yea, that's the weird part. When I had a 5800X, I was setting it up in the AMD Overclocking section and not "Extreme Tweaker" or whatever they call it. But now I do not have PBO/CO in the AMD overclocking section since upgraded FM and to the 5800X3D. So maybe it isn't enabled on the CH8 for the x3d parts. I thought I read others had it working on this board though.
The 5800X3D doesn't officially support PBO or curve optimizer. When the 5800X3D was released, no motherboards had PBO or curve optimizer as an option with this CPU. This is because the extra cache is very sensitive to voltage changes, and also acts as an insulating layer on top of the CPU cores, creating all kinds of issues when tweaking the CPU for only very minimal performance gains.
But some motherboard manufacturers later added Curve Optimizer and PBO support back into the BIOS for the 5800X3D anyway, without AMD's blessing. If you have one of these boards, it doesn't surprise me at all that curve optimizer and/or PBO would "work" in the BIOS but would still not be available via AMD's official Ryzen Master software. There is a software program, "PBO2 Tuner", that should allow you to adjust your settings in windows if you still want to pursue this further.
Well I didn't clear cmos, but I reverted to previous bios, then updated to newest one again. For some reason I'm having an issue with the LEDs on my board on the newest BIOS. Can't turn them off, there's a green one that stays lit. CO did not show up after flashing twice, oh well. Thanks for the help everyone. The system runs well, so just tinkering to tinker. I'll leave well enough alone. Temps don't go above 65/70 when gaming, so CO probably wouldn't have done much anyways.
Any idea which board vendors have this and which don't?
I didn't need PBO for my X570S MEG ACE MAX and 5800X3D. Just set a -20 core offset, and while gaming the all core frequencies were always maxed out.
This isn't a dark hero (although I do have knr left that'd never been opened lol) but I just tossed together this 5800X-3D, 32GB of B die @3400c14-14-14-380-1T, 500GB+2TB E18 186L NAND ssds, and an OEM 3090 together for a customer.
Build is on water with EK all nickel monoblock and EK front/rear GPU blocks and a pair or 360mm Alphacool all copper 45mm think rads paired with 6x reverse airflow Thermalright TC-12 fluid bearing fans intake and 3x TR TC-12 in exhaust.
I just did a run of CB20 with the stock CO settings for a baseline and then one with all cores set to -10. CB20 went from 5495 stock to 5652. So CO is clearly working.
Like you, it isn't in the old AMD OC section. It's in Extreme Tweaker.
Pics below.
  • 20240621_144114.mp4
    8.4 MB
Be careful, its easy to burn out the 5800x 3d. I doubt you will gain much but run a real risk of melting your CPU.
What?
How?
They are clocked close to the maximum out of the box and due to the stacked cache memory it's hard to get rid of the heat even with a big cooler. I won't pretend to be an expert on the subject but do some homework on the subject before trying to OC them . Modern CPU leave little headroom compared to say an older Quad 6600 which could take a 50 % 0C with good cooling . The power law governs heat increases and a small increase in voltage of 10% could yield a 25% or more increase in heat . In fact under locking via a small voltage decrease can actually yield better frame rates as your CPU is not throttling. Again I don't claim to be an expert on this but have found that more cooling generally means more noise as fans max out . My 6800xt runs better when undervolted and with the Freq restricted to 2300. Less noise and less heat for no noticeable decrease in frame rate.
AMD says the voltage restrictions are due to voltage limitations of the added cache, however, our testing indicates that the limitations almost certainly have something to do with the chip's heat dissipation issues.30 Mar 2023 Toms Hardware
