curious problem
soup666
currently im running a 4870x2 and trying to play borderlands 2. however i notice im only getting 30fps. but, when i go to my desktop and then click back into borderlands 2 i get 60fps (probably due to the game being capped at 60 fps through default settings) and it stays like until i get to another load screen, then it drops to 30fps until i repeat the process of going to my desktop and then clicking back onto bd2. v-sync is not turned on in game, i've also verified that ccs doesn't have v-sync on, as far as i can tell, V-sync is not on at all. can some one help explain. im completly furious
well you gotta consider that i have a 4870x2. im assuming thats the latest for my vid card.
ive been using ccc auto update and ive treid a newer version and couldnt ccc intaller blocked me.
not sure if its cf driver related issue because in windowed mode i get 30fps too
Yeah, there probably isn't anything driver specific for your card, but it's the crossfire profiles that you're after. You should be able to install those separately too. CF doesn't work in windowed mode I believe, so 30FPS in windowed makes it sound like that's just one of the GPU's, and then 60FPS is with both.
