Curiosity
Tormond
[H]ard|DCer of the Month - June 2007
Are teh Athlons just much better at folding than the P4s? Looking at EM3 My athlon seems to be doing about 1 Frame per 8 min (per CPU) (X2 4400+) My P933 about 1 Frame per 27 Min (It is a dual 933 and that is per CPU) and I just installed a P4 3.2Ghz 800FSB w/HT and it is only putting out about 1 frame per 17 min (per CPU). This just seems wrong to me or have I just been hiting the pipe too hard lately?
It all depends on what protein you're chewing through on which CPU. AMD flies through Tinkers, but sucks as Villins (I get 25ppd on my 2100+ w/ them). But P4's can just crank through QMDs. Too bad Stanford doesn't match CPU to Protein better, it'd be in their best interest.
well right now the P4 and the AMD are both working on Ambers and getting the above numbers (well one of the cores on the X2 has a Gromac)
I "think" my dad has an AMD XP 1800+ (which ever one ran at 1535mhz).
It averages 140PPD.
I have a P4 2.8GHz with HT running two consoles, which averages 235PPD. So in my case the AMD XP is a tad bit better, especially considering the P4 is running 2 consoles.
My AMD Opteron 252 @ 2.6GHz averages 350PPD
A P3 800mhz averages about 75PPD (similar to the AMD XP)
Compared to the Pentium M, these are very inefficient. My Pentium M 1.5GHz laptop averages 225PPD, much better then the others, and uses much less power ^_^.
~Hope this helps
