I the old saying is correct; "If it ain't broke, don't fix it." Well...
I formated my box a couple days ago. I'm running Windows XP Pro SP2 with all of the latest updates. I'm having a problem where Ctrl + Alt + Del won't end frozen applications. For an example, GTA:SA froze and I attempted to terminate it yet no matter how many times I clicked "OK" to terminate the process, it didn't do jack. My users dialog (via control panel) locked up and it would not end the process. MSN Messenger recently froze and it would not terminate the process. This is just a few examples. Any ideas?
I'm thinking it's a very simple fix.. right? ;-)
Thank you.
Thank you.
