CSS Syntax Question
Tim_USMC
Trying to fully learn CSS, and I'm coming across this one occasional syntax that I cannot find any documentation about.
That is the '>' operator. Here is an example of it being used:
Code:
ul.nav li>ul{
/*Make the sub list items invisible*/
	display: none;
	position: absolute;
	width: 20ex;
	left: 20ex;
	margin-top: -1.4em;
	margin-left: 9px;
So this style applies to <ul> elements with the class of "nav", then <li> elements nested within that...
But what does the '>' imply? Is that just a designator for another level of nesting?
Like
<ul class="nav"><li><ul>...</ul></li></ul>
i've never seen that before and i've been using CSS for almost half a year now....
where'd you find that code anyway?
ul.nav li { }
li is a descendant selector in this case and would do:
Code:
<ul class="nav">
    <li>style this</li>
    <li>style this</li>
<ul>
That means, any li in a ul with class="nav" will be styled.
ul.nav li>ul {}
li>ul is a descendant child selector and would do:
Code:
<ul class="nav">
    <li>
        <ul> <-- style this
        </ul>
    </li>
</ul>
That means, if an ul elment is a child of an li element that's a descendant of a ul element with a class of 'nav', the ul element will be styled.
http://www.w3.org/TR/CSS21/selector.html#child-selectors
child selector
That's what I was looking for, but couldn't find any documentation. Thanks!
