Ok, I have an admin site I am working on, but have run into a problem. I am using examples from the site http://www.quirksmode.org/css/forms.html to do form layouts, but am running into a problem when inserting it into my layouts.
The problem is this, the br's "clear: left;" is clearing all floats to the left, not just the one in the container div I was it to. Is there a way to prevent this? I will try to show an example:
<div float: left> <div> <div float: right>
The left and right columns are for menu and navigation and stuff. When I insert the example code as listed previously in the center div (for content), it breaks the form up, causing it to put the 2nd form entry field after it has cleared the menu navigation div on the left.
I have alos pulled the page in question into the following URL:
http://tt.8xmedia.com/test.html
