CSE-847E2C-R1K28JBOD
Discussion in 'SSDs & Data Storage' started by Irockzz, Mar 11, 2019.
  1. Farva
    Farva [H]ard as it Gets
    35,101
    Feb 3, 2004
  2. Irockzz
    Irockzz n00b
    39
    May 27, 2016
    Just curious I’m picking up the server and two of the disk shelves for a really good price
  3. Irockzz
    Irockzz n00b
    39
    May 27, 2016
    20190311_171001168_iOS.jpg 20190311_171001168_iOS.jpg 20190311_173731747_iOS.jpg 20190311_170709166_iOS.jpg 20190311_173712914_iOS.jpg 20190311_173731747_iOS.jpg 20190311_173744746_iOS.jpg Previews
  4. Blue Fox
    Blue Fox [H]ardForum Junkie
    11,638
    Jun 9, 2004
    You have the SKUs wrong. The top one is a 6047R-E1R36L. Bottom is a most likely a 847E16-R1K28JBOD (could be older and be a different SKU, but one would need an interior shot and the power supply model to tell).
    If you're not terribly familiar with these, they're probably overkill for what you're needing. If you're going to use them at home, power consumption/noise might be quite the surprise.
  5. Irockzz
    Irockzz n00b
    39
    May 27, 2016
    I will grow into them just like I did with my c2100's
