cs server connection problem : (
Akram
I have this problem where i can not join the same server as my brother in the other room on the same router. he can be in a server, and if i try to join the same server as him it just says that the server is not responding, and its the same if i am in a server and he tries to join. SOMEONE HELP! PLZ!?
I suppose it's possible that the server disallows concurrent connections from the same IP address to prevent ghosting/etc.
You may be able to get away with hooking a switch up before your router, and having one PC come off of that, assuming your ISP allows for multiple DHCP addresses.
Server doesn't allow more than one machine on the same IP.
Is this results reproducible with other servers?
the server will not allow 2 Steam IDs on the same IP at the same time.
