CS:S on X1800 XT
solideliquid
I run CS:S with 1280x1024 and while playing the HDR maps (esp. Militia) I need to turn the settings down to AAx2 AFx4 with HDR on to maintain +40 fps average. I do not want to fps dropping below 30 at all.
I think my settings are not AAx4 AFx16 (AD, and HQ AF) like I can run offline with bots because of my connection.
How are you guys running CS on the HDR maps?
you think that is bad... I can't even play CS 1.6 with my 7800 GT's... I don't know why, but I get between 15-40 fps... but usually maintains in the 20's... I put fps_max 101, etc etc... I know all the commands... been playing for like 5 years now. Oh yeah, I use Direct 3D...
I checked all my settings, turned v-sync off, ect ect... I can't figure it out. This card rocks for all the new stuff, but it feels like it's not backwards compatible with old games. hahaha...
your card should be strong enough to Handle HDR.. are you using Direct 3d or Open GL? I know for a fact, that Open GL is perfect for ATI cards... so you might want to give that a try.
"your card should be strong enough to Handle HDR.. are you using Direct 3d or Open GL? I know for a fact, that Open GL is perfect for ATI cards... so you might want to give that a try."
Um actually ATI is stronger in D3D. Also, Counter-strike: Source, is only available in D3D. Man it's a problem with the map. Nuke runs fine right? It's just militia?
I'm not sure if your results are as bad as you think, I'll give you my setup and results just so you can compare...
Check my sig for my hardware, and here are my CS:S settings..
1152 res., all on High, no Vsync, 2xAA 4xAF
I don't play Militia too often, but I found a spot where I have the least FPS (outside of the covered bride on CT side, near the waterfall, but standing on the path between trees itself)
I get approx. 35fps, just standing still
So, make sure your card is running at 8x AGP mode, this is the problem I was having a while back, it was forced to 4x AGP until i fixed it.
it valve and their game that they need to optimize it and make it bug free
Other wise I love CS: Source
My X800XT stock speeds 1280x1024 2xAA / 4x AF and everything else on the highest settings
I get anywere between 30-100FPS depending on the amout of people, server, and what kind of battle I am in. They jsut go up and down at any given time :rolleyes:
x850xt pe running cs:source at 1600x1200 with 4aa/16af and my fps are always above 40
I have a 7800gt and it plays those at 1200x1600 4xAA and 8x (or 16x I cant remember) AF and it runs cs:souce always above 40fps. I dont know what it is with your x1800xt, but it should perform at least as good as mine... Maybe try reinstalling the drivers.
All games based on the HL1 engine play best with OGL not D3D.
Open GL is better ran on Nvidia cards, hence Doom III, which is based on Open GL runs a lot better on Nvidia cards.
ATi specializes in D3D
3.4EE @ 3.9GHZ X800XT-PE
1680 X 1050 Everything on high.
HDR on
2x AA 16x AF
Always above 40fps
I run an X800XT. I play CSS @ 1280x1024, and I turned HDR off. Besides being completely useless, it managed to crash my game everytime I would load and play de_nuke for 5-10 minutes.
I play with these settings: 1680 X 1050 Everything on high, 4AA 16AF, HDR On, always above 45fps using the system in my sig. (x1800 xt is still in my shuttle, not installing the x1900xt till ati releases 6.2cats)
I run CS:S's Militia at a low 30 highest 80 average 60 on 1280 x 1024, 4x AA 16xFA on a x1800xl. Something is wrong with your rig.
I can run Lost Coast at 1280x1024 with everything set to high (reflect world), AAADx4 AFHQx16 and HDR on for a low of 32, ave 50 and high around 100 so it's got to be my slow DSL.
