I believe wayne ment that you could simply measure your bay size with a ruler, and compare that to the size of the LCD, which you could easily find on the net. Just a guess though....
with quite a bit of modding it will work, but going straight into the 3 1/2 bay with just a simple bracket is a no. The PCB for those screens is a little over 5 inches.
i'd take my 3 3.25 bays, glue it togther, put wodden mounting brackets in the corners, then cut it out throw the lcd in, but the cd is gonna be with at the edges
being a CF owner and seeing many different models of the CF displays(its the display preference of the LAN i go to) the 634 takes up 2 of the "CD-ROM" bays the 631 takes up a floppy bay and has control buttons (but the software/hardware is still in beta) the 632 i belive takes up a floppy bay with out buttons, and the 633 is the size if a 631 but takes up a 5.25 cd-rom bay but the control buttons do work
