Crysis tweak question
Krenum
Hello, Im trying to get into playing Crysis, it plays ok for what I have I guess, I have a tweak guide somone posted here a few weeks ago, but I need to access the (autoexec.cfg ) file, says its in the base folder in the crysis directory, I cant find it , is there some other place I should be looking to access the ini files ?
you will need to make it yourself :)
I've gotten good results running it in dx9 mode, using the tweaked cfgs found at incrysis.com, and using the .13 drivers that came out today
...but i'm holding out for the patch (might be tomorrow :))
base folder meaning root install directory
C:\Program Files\Electronic Arts\Crytek\Crysis
right, but what file type do i create , a text file?
sure but when you're done with it rename it from autoexec.txt to autoexec.cfg
